Author Topic: Tail swaps  (Read 454 times)
Offline Krizla
Tail swaps
« on: March 01, 2010, 12:27:57 PM »
Ok so I'm going round various places looking for bits n pieces to do to the Thundercat when she turns up.
I'd like to swap the tail unit for something a bit cooler (R1 / Duke 848 are top of the list) and maybes do the front as well (Sheps says an R1 can go on).:wink:
Thing is, I've nae a clue how to start. Is it possible to get conversion kits? Should I stick with one manufacturer (ie Yam to Yam bits)? Should I build a mock up to suit something I've bought?  Help! :rolleyes:
Could we get a 'how to' from someone in the know? :smile:
Buy me a bullet and rent me a gun............
Offline Filthy
  • Now then now then!
  • Global Moderator
    • http://www.freebronson.co.uk/
Tail swaps
« Reply #1 on: March 01, 2010, 12:32:25 PM »
Buy seat unit and subframe, chop off old one, get new one welded on with tip of tail about level with tank. - Job jobbed.
HAPPY TO HAVE HAMMERED A FEW NAILS INTO THE COFFIN OF STREETFIGHTERS MAG
Offline "M"
  • Honorary Member.
Tail swaps
« Reply #2 on: March 01, 2010, 12:46:12 PM »
As zyk says.
Buy the tail unit and subby you want to fit, chop off the old.
Get new tabs welded on and theoretically, jobs a good un.
Incompetant!
Offline Krizla
Tail swaps
« Reply #3 on: March 01, 2010, 01:56:55 PM »
Oh, easy as that then. I'll get to it.:rolleyes:
Offline "M"
  • Honorary Member.
Tail swaps
« Reply #4 on: March 01, 2010, 02:23:26 PM »
I'd say commit to doing it, chop the cat subby off now!
Cut it off as damn close to the frame as you can but dont touch the frame with yer disc (buy 1mm cutting discs for this).
Once its off get as much of it on eblag as possible.
Going back to whats left stuck on the frame......120 grit disc in yer grinder and gently grind off as much as the surplus as you can without touching the frame.......stop when its a gnats proud of the frame.
Now stick scothbrite in yer grinder, and put it flat on the bit left thats proud. The technique now is to use a gentle side to side motion without adding much pressure until it starts scuffing either side on the frame.
Always keep your grinder flat and moving when finishing, dont ever dig at it with the grinder, Flat, slow and gentle being the key words :big grin:
Incompetant!
Offline Sheps
Tail swaps
« Reply #5 on: March 01, 2010, 04:23:18 PM »
Ye said an R1 can go on. But also said it looked HUGE :rolleyes::lol:
Summin small you want cause of the frame shape, seat starts pretty far back so thet look to hang out the back alot :shakeno: Hence Ive never changed mine yet :wink:
It's good for two things, degreasing engines and killing brain cells!
Offline ace
  • Sr. Member
    • http://www.aceofsprays.co.uk
Tail swaps
« Reply #6 on: March 01, 2010, 07:20:11 PM »
I am using an XJR1300 tail piece chopped and slimmed down, mostly because i had it in the workshop, but also coz they dont get used too often, and they are quite short, perfect for the single seat look.
Offline Sheps
Tail swaps
« Reply #7 on: March 01, 2010, 07:29:49 PM »
Quote from: ace;265427
might have to pinch that idea myself :big grin:
Offline Krizla
Tail swaps
« Reply #8 on: March 01, 2010, 10:01:06 PM »
See, now neither of us can post up ideas cos the other one will nick em! Wow, this must be what owning a Gixer is like!:wink:
Just for laters but do you have a TIG welder?:rolleyes:
Offline Sheps
Tail swaps
« Reply #9 on: March 01, 2010, 10:03:45 PM »
Quote from: Krizla;265491
Steel frame mig will do :wink: got 1 or 2 kickin about (and a grinnder) :big grin:
Offline Krizla
Tail swaps
« Reply #10 on: March 01, 2010, 10:08:26 PM »
Oh right, we're they all steel frames? Mines a 98, can't remember your one...
Sounds good, might have swing some beer your way for a shot.:big grin:
Offline Sheps
Tail swaps
« Reply #11 on: March 01, 2010, 10:10:38 PM »
Quote from: Krizla;265493
As far as i know they were all steel. Beers always good :thumbs:
Offline Sam21:19
Tail swaps
« Reply #12 on: March 02, 2010, 10:19:43 AM »
:big grin::big grin::big grin:
:freaked::freaked::lol:
Offline "M"
  • Honorary Member.
Tail swaps
« Reply #13 on: March 02, 2010, 10:53:09 AM »
The cat has an ally frame.
Incompetant!
Offline Sheps
Tail swaps
« Reply #14 on: March 02, 2010, 08:41:08 PM »
[QUOTE="M";265551]The cat has an ally frame.[/QUOTE]
Ace has an alloy frame, Cat has a steel 1. Was gonna polish mine til it started rusting, so cant be alloy :wink:
