It lives
Posted: Sat Jul 17, 2010 4:10 pm
by Tom mccrea
I got her running but air mixture must be awful! Won't tick over on her own, wee bit of revs required however I don't think my neighbours in Carrick appreciate it as must as I do!
Can anyone advise? Sounds a bit clunky, am I paranoid?
Re: It lives
Posted: Sat Jul 17, 2010 9:00 pm
by extonyg
check for air leaks also make sure idle is set ok but ye mixtures may need adjusting.
does the noise go away when the clutch is pulled in?
Re: It lives
Posted: Sun Jul 18, 2010 12:42 am
by Tom mccrea
Haven't tried the clutch yet as the cable is buggered. The whole thing will need set up. To be honest I'm just pleased it started. Diagnostics time now for everything else...should be fun but strangely I'm looking forward to it...
Re: It lives
Posted: Sun Jul 18, 2010 9:01 am
have you cleaned the carbs out? If its been standing for a while itll need doing. May just need a good run to clear it all out.
Re: It lives
Posted: Sun Jul 18, 2010 11:03 am
by Tom mccrea
You're prob right about the carbs...and the rest for that matter. Need to get this oil situation sorted. Changed it yesterday so will give it a check then possibly again with an engine flush. Hopefully the head won't have to come off!!
Then it's carbs, electrics and bodywork and hopefully breaks to finish her off
Re: It lives
Posted: Sun Jul 18, 2010 4:05 pm
what colour was the oil that came out?
Re: It lives
Posted: Mon Jul 19, 2010 5:18 pm
by Tom mccrea
it was a terrible creamy coffee sort of colour... Hard to describe really.
Re: It lives
Posted: Tue Jul 20, 2010 8:11 am
hmmm, sounds like water has gotten in there. Have you found the 'split pipe' yet?
Re: It lives
Posted: Tue Jul 20, 2010 5:46 pm
by Tom mccrea
No 'split' pipe as yet... More like split gasket I think. Need rip all that stuff of the top and get a bloody good hoke around. Unfortunately work and 'her' have taken over the last couple of days so gonna try to put my foot down and get my finger out!
Re: It lives
Posted: Fri Jul 30, 2010 10:14 am
by Dolts
Sounds very much like a head gasket failure to me, that would explain the problem with it idling too as there will be a lack of compression.
Re: It lives
Posted: Sat Jul 31, 2010 12:01 pm
by Tom mccrea
Turns out it was petrol in the oil! The engine seems ok, need to sort the brakes out then it's up to nutts corner race track for a couple of hours for a blast around and see if anything goes wrong. Will have to set carbs too but I suppose Rome wasn't built in a day...
