starter motor
Posted: Thu Jan 27, 2011 8:16 pm
by mikeyjp1980
Hi All,
After a cold winter I replaced the battery with a new one but now when it starts up it there is a clunking noise. I think its a sticky starter motor as it seems to catch and start. Can any one help with how to remove the starter motor ??
Re: starter motor
Posted: Thu Jan 27, 2011 8:22 pm
more likely to be the starter clutch mechinism behind the genny cover
Starter motor is removed by disconnecting it and undoing the two M8 bolts holding it then slide it out of the crankcase. Make sure you dont lose the O ring
Re: starter motor
Posted: Thu Jan 27, 2011 8:31 pm
Im assuming you charged the new battery and the noise you hear isnt the starter relay?
Re: starter motor
Posted: Wed Feb 02, 2011 9:23 pm
by Jamz
It could also be the pin in the starter relay?
You never said if it IS starting or not? Is this just a noise you've only just noticed? If so, then it's always been there and it's fine!
Re: starter motor
Posted: Sat Feb 05, 2011 7:23 pm
by mikeyjp1980
Funny story. The bike cut out on the way home from work last night no noise just cut out whilst riding. I tried to start it and it would not start. I left it and tried agian but the starter was not even engaging just making a nasty ringing noise. Left it over night and tried it today the starter made the same noise then the bike started. ( just my luck as last night I had to call recovery to take me home doh.) So iM not sure if its the starter or the alternator as it cut out whilst riding.
Re: starter motor
Posted: Sat Feb 05, 2011 10:19 pm
by Jimzxr400L1
hiya , mite be way off topic just thought i would metion it my bike always used to cut out whilst rideing on the over run like rolling upto a set of lights ect found out it diddnt have a thermostat and was running to cold . anyway if your alternators nakered just check what voltage to battery is when running i know on a car about 14.2v is the best charge rate ...not to sure on a bike pal !! ....Jimbo
