ZXR 750 1991 J1 AIRBOX HELP! :D
Posted: Tue Jul 28, 2020 1:52 am
by RickTaff
So this is the bottom of a zxr750 1991 J1 model airbox. The right hand spout which is plugged off, was where the drain tube would be. Apparently its fine to plug them off, it does not affect performance of hurt the bike
But, what on earth is the hole directly on the bottom for? Is it meant to be plugged or can i leave it open. Not sure if correct pipe is on the bike or not, as i havent really had a good look. When i bought the bike, the airbox was already removed to clean carbs
Re: ZXR 750 1991 J1 AIRBOX HELP! :D
Posted: Tue Jul 28, 2020 7:57 am
by banner001
Crank breather, though it looks a bit wide for that?
Some kind of ram air/pressurisation system?
Egr valve, or California emissions breather?
When you mount the airbox is it very close to anything?
Posted: Tue Jul 28, 2020 6:37 pm
by RickTaff
I've a suspicion it goes onto the hole in this picture. This is the lower part of the engine which the airbox would sit right above
Posted: Tue Jul 28, 2020 7:41 pm
by Miles
Looks very much like the crankcase breather
Posted: Tue Jul 28, 2020 8:34 pm
by RickTaff
Miles wrote: ↑Tue Jul 28, 2020 7:41 pm
does it not sit on that hole i pointed the arrow to in the pic?
I suppose i could contact a local dealer and ask them.
Posted: Tue Jul 28, 2020 11:03 pm
by banner001
I'm guessing that there will be a rubber grommet that fits to the airbox, then you press that over the crankcase breather (that's the bit with your arrow)
That's the same way my zxr250r does it too...
Posted: Wed Jul 29, 2020 12:11 am
by RickTaff
banner001 wrote: ↑Tue Jul 28, 2020 11:03 pm
Thanks. Have looked at an exploded parts diagram, and it shows a pipe going to tha hole on the bottom of the airbox, with a plug in the end of the pipe.
