How do micron cans fit micron pipes?
Posted: Mon May 14, 2007 10:28 pm
by Lee
I haven't been on here for a while so il give a brief update. I managed to buy a cheap zxr with a seized engine in the winter, since then iv bought a second working engine and stripped and cleaned everything up. I also won a set of micron down pipes off ebay the other day (waiting to be received) but im startin to wonder how a micron can attaches as it just looks like a pipe end with no mounting etc from the picture. Does anyone have a micron full system? Also are there different variations in the zxr micron downpipes?
Ta in advance for any replys.
Posted: Mon May 14, 2007 10:40 pm
As far as i know the Micron pipes for ZXR require a slip on pipe. So instead of a mounting plate and three bolts as you get with a standard ZXR you get just the end of the pipe with a Micron, and the appropriate Micron can just slips on and you do up a jubilee type clip.
:smt001
by Northern ANdy
I've got a race micron which is a bolt on to the standard system. And now I've got a set of SS micron Dp's which are a slip on system with road can.
I intend to fab something to fit the race can onto the slip on link pipe
Posted: Mon May 14, 2007 11:04 pm
by Lee
Ah right, got it now, thanks guys. Next guestion; Are there any other manufacturers that have a slip on arrangement that will fit the micron pipes, i.e. scorpion, arrow etc? i suppose it will depend to the diameter of the pipe though.
Posted: Mon May 14, 2007 11:50 pm
by kurty_22
i have a full micron system on my bike and my end can fits on just the way RobB said.
Posted: Tue May 15, 2007 12:09 am
by Xphyral
I'm not aware of any other manufacturer that produces a can to fit micron pipework, they use a much larger bore.
Posted: Tue May 15, 2007 10:12 am
by Northern ANdy
micron link pipe is 63mm for reference
Posted: Tue May 15, 2007 10:13 am
I had a scorpion slip on end can but that went on Nassert Beet link pipes, that was a 35mm bore. And as Xphy quite rightly stated, Micron use a larger diameter pipe.
Posted: Tue May 15, 2007 10:39 am
by rene
if the mircon link pipe is 63mm then just email some companys
Carbon can Co do made to order cans so they will fit onto the pipe work
Posted: Thu May 17, 2007 6:38 pm
by Dylan
All that matters is the diameter of the pipework. You will find that bikes like the ZX10R, mille etc have the same diameter that you are looking for.
