SERVICE
Posted: Fri Aug 31, 2007 7:55 pm
hi all,
what do you pay for you services? where do you get them done and what does it include?
i've been offered a "full service" for £250-£300, which includes:
check pads, discs, flush fluid and replace.
balance carbs and adjust idle speed etc.
flush coolant system, check thermostat, replace coolant and thermostat if needed.
flush oil system, replace filter and oil with fully synthetic stuff.
replace fuel filter and air filter.
check valve clearances, adjust if needed with new shims
check cam-chain, replace if needed
change cam-chain tensioner if needed.
other general checks on the frame etc, adjustments that could be needed elsewhere and general road-worthyness checks
i dunno if that sounds good or bad to you lot? but i know the guys as i work 2 shops down, i'll watch them do it so i can learn how to do it again for myself. plus all the other benefits of getting the work done by professionals. let me know what you think and what you pay for your services.
carsounds_dan
carsounds_dan
