colortune
Posted: Mon Dec 15, 2008 1:24 pm
by steve87
I have got to say, they are very very good, and I am very impressed with this, such a simple desing, and work so very very well, I would definitely advise getting one, if you need to re jet or check carb balance etc, definitely a worthwhile peice of kit, even at £30
steve oldman
Re: colortune
Posted: Mon Dec 15, 2008 2:49 pm
how does the colourtune check your carb balance? i thought it just gave an indication to your mixture?
Re: colortune
Posted: Thu Dec 18, 2008 7:47 am
by MillaMeter
Hi,
I think steve means that you can balance the mixtures, not the carbs... right?
My bro had 1 of these kits for his TZR125, decent piece of kit indeed! Basically you replace any spark plug(depending on the cylinder you're tuning) with this special glass 1, when you look down into the combustion chamber, you can see the colour of the flame that is burning. You then get this colour chart and match the colour of the flame with the chart. Say like the flame is too dark against the chart, you then adjust the mixture on that carburettor to get the colour perfect or something like that. Was a long time ago when I saw my bro use 1.
Regards
Rich
Re: colortune
Posted: Tue Apr 21, 2009 12:27 pm
by lewisdale
might b right at idle but wat about at speed? or if its right at idle is that good enough?
Re: colortune
Posted: Wed Apr 22, 2009 3:04 pm
by tk400
GET A WIDEBAND OXYGEN SENSOR !!!!
colour tune is for balancing twin SU carbs and other such things. No good for mixtures on a bike above idle. Now that the common man can obtain wideband units they are the best option....cheers
