Page 3 of 3
Re: The story so far
Posted: Sat Feb 01, 2014 7:49 pm
by Dorset shortwing
Quick update . Christmas saw the arrival of my viton kit but haven't had time to fit them so have been putting up with the rough running until last week when it started not pulling above 5000 rpm so today stripped and cleaned carbs again and replaced all the o'ring's and the only ones i didn't change were the tiny small one's as i couldn't for the life of me find out where they go and i was in a garage with no internet connection to check. The main jets are standard 95's and float hight's are good so once back together it run's better but still takes a while for the rev's to settle on idle but response is far better but as for the top end lean running i will let you know as i haven't been for a blast as i have just finished and i can't be arsed so will give it a run tomorrow .
As suspected all o'ring's were flat and brittle especially the needle jet seat ones . I took the pilot screws out 1.5 turns as they were 2.5 turns out .
Posted: Sun Feb 02, 2014 2:30 am
by KwakKwak
Tiny O rings to the pilot screws, worth checking, they will be shot too, if they're even on the screw, last two sets I've stripped were missing all four in one case and one O ring and washer in the other, spring washer then O ring, bingo.
Posted: Sun Feb 02, 2014 12:42 pm
by Dorset shortwing
KwakKwak wrote:Tiny O rings to the pilot screws, worth checking, they will be shot too, if they're even on the screw, last two sets I've stripped were missing all four in one case and one O ring and washer in the other, spring washer then O ring, bingo.
Ah ,,, there were none on any of pilot screws nor washers
:smt013
Posted: Sun Feb 02, 2014 5:24 pm
by KwakKwak
Dorset shortwing wrote:Ah ,,, there were none on any of pilot screws nor washers
:smt013
A definite theme developing with the pilot screws, are people removing these with their eyes closed before reseating them and adjusting???? Maybe the O rings and washers aren't important, garage floors across the country littered with tiny washers and O rings
Posted: Sun Feb 02, 2014 6:11 pm
by Dorset shortwing
Any idea of the washer size Kwack ?
Posted: Sun Feb 02, 2014 7:32 pm
by KwakKwak
Dorset shortwing wrote:Any idea of the washer size Kwack ?
Approx 5mm outer dia. with a 3mm dia. hole, whether they are made specifically for the screw I don't know, but Cradley have them, I had to order 1 the other day, biggest parcel you've ever seen
The thickness will be critical too, so be safe and get the correct washer.
They cost about £2.00 each from Cradley, so maybe try your local Keihin specialist and save a few bob, or follow any ZXR owners home and search their garage floor, I'm currently doing a ball bearing search of mine, one little fookers hiding on me :smt013
Posted: Tue Feb 11, 2014 8:52 am
by ross46
So is that why my pilots are out, I left the washer and o rings in!
Posted: Tue Feb 11, 2014 1:46 pm
by KwakKwak
ross46 wrote:So is that why my pilots are out, I left the washer and o rings in!
You and me both mate, we must be a pair of weirdos, keeping the O rings and washers in place, pah
Posted: Fri Feb 14, 2014 7:59 pm
by ross46
i might put that on my bike "weirdo coming through!"
Posted: Sun Mar 09, 2014 5:54 pm
by Dorset shortwing
Just got around to fitting the pilot jet Orings and washers and the bike is slightly better but still couldn't pull the cock of a gnat
. It will pull reluctantly to 12000 rpm but have to whack the choke on at higher rmp for a slight improvement ,,i have set the pilots two and a half turns from fully in ,,,,quite lost now but at least idle is better
Posted: Mon Mar 10, 2014 11:09 am
by ross46
the pilots will only change the 0-4k rev range, at high revs it's your main jet, what are you running main jet wise? i have some spare jets which you could try first before buying if you want to? ride through the rev range and add choke and find out at what revs you need choke then you can try adjusting the pilots, needles and mains. obviously the best thing to do is put it on a dyno but you can get it pretty close by feel normally
Posted: Mon Mar 10, 2014 7:23 pm
by Dorset shortwing
ross46 wrote:the pilots will only change the 0-4k rev range, at high revs it's your main jet, what are you running main jet wise? i have some spare jets which you could try first before buying if you want to? ride through the rev range and add choke and find out at what revs you need choke then you can try adjusting the pilots, needles and mains. obviously the best thing to do is put it on a dyno but you can get it pretty close by feel normally
Cheers Ross , she is running standard 95 main jets and now pulls cleanish to 6000 rpm then if you add choke it picks up a bit but nothing like it should.
Posted: Mon Mar 10, 2014 11:49 pm
by banner001
needs M3 washers under the needles and/or larger main jets.
