Carb Seal Kits in viton
maelstrom
Hi All,
With the help of Ross46 I finally got these done.
http://litetek.co/Carb_Kit_Kawasaki_ZXR400.html
cheers
Blair
cheers
Blair
Carb kits in viton
http://litetek.co
http://litetek.co
ross46
- Restricted
- My Bike: zxr 400 l6
Re: Carb Seal Kits in viton
my pleasure, i'll be fitting these to my spare set of carbs so i'll put on here how it goes, by the looks of it these include all the seals that are required to split the carbs? and what does 1300 tbh convert to?
maelstrom
Yes the fuel hose, breather o-rings, and choke plunger dust caps are also included.
Carb kits in viton
http://litetek.co
http://litetek.co
- KwakKwak
- My Bike: ZXR 400L9 2001
Diagram shows these for the H, I assume all seals on the L9 are the same, float bowl O ring most importantly, cheers.
maelstrom
Matching Kawasaki part numbers are shown on the web page. To the best of my knowledge the parts are the same between models.
cheers
Blair
cheers
Blair
Carb kits in viton
http://litetek.co
http://litetek.co
- KwakKwak
Cheers Blair, busy stripping bike and was being lazy, too busy to check, just hoped someone would know, will confirm and get an order in.
ross46
- Restricted
These are massively high quality, I thought my carbs were fine, put the seals in and im now busy perfecting them, must have been leaking internally and I didn't even know! Worth every penny
- KwakKwak
They definitely fit an L then? Checked Cradleys and part nos for the H and L are the same, just thought the H carbs were a different size, could be that i,m being a plonker though
Carbs come off today, judging by the mess between the airbox they will need this kit badly.
ross46
- Restricted
Fit the L perfectly, only advice I would give is maybe smear a little silicone in the float bowl grooves to hold the seals in place
- KwakKwak
Cheers mate, stripped mine today, they were shot, will be ordering tke kit later.ross46 wrote:Fit the L perfectly, only advice I would give is maybe smear a little silicone in the float bowl grooves to hold the seals in place
jack1605
- My Bike: kawasaki zxr400h
Hi all, I just stripped my carbs and got them ultrasonicly cleaned, they're mint but I need new seals as the old ones are fubar'd. How long do these kits take to arrive in the UK normally? Cheers.
maelstrom
Hi Jack,
About 10 days to the UK.
cheers
Blair
cheers
Blair
Carb kits in viton
http://litetek.co
http://litetek.co
jack1605
Awsome, thank you very much.
ross46
- Restricted
AHHHH MAN i forgot to redo the pictures with your seals :/ would you like me to do a post on how to fit all of your seals with pictures and instructions then you can direct people to that post?
maelstrom
