Hi I have a h2 which on start up on choke the res are very high, 8k, I've cleaned the carbs but still the same. Once you play around and get the bike warm it ticks over fine off choke and rides fine. Is there any adjustment for the choke ?
Cheers Simon
High revs on choke
- Restricted
- My Bike: zxr 400 l6
Re: High revs on choke
You should be able to start the bike without the choke normally, unless its cold etc, my bike revs up high on the choke aswell, try adjusting the pilots
- My Bike: Zxr400
Cheers mate just tried with no choke and it's fine, don't know why I didn't tried without ? Lol thanks againross46 wrote:You should be able to start the bike without the choke normally, unless its cold etc, my bike revs up high on the choke aswell, try adjusting the pilots
- Restricted
No problem, probably just habit, I did it after getting off my rs125
