Page 1 of 2
				Fumes.
				Posted: Thu May 29, 2014 2:06 pm
				by KwakKwak
				Does anyone using Superplus or similar, and garaging their ZXR find after a fill up and warm day run out the fumes are bad from the breather.
Please say yes, as otherwise I have a mystery leak, carbs are just recently back on the bike and all seemed dry and well.
I'm hoping it was just the shock of a warm day, I do not want to strip it down again, bike is also sitting on a fetching dusky blue carpet which is bone dry with no petrol whatsoever on it.
Ta.
				Re: Fumes.
				Posted: Thu May 29, 2014 2:21 pm
				by CaNsA
				Mine always smells of petrol, it runs slightly rich.
				Re: Fumes.
				Posted: Thu May 29, 2014 2:36 pm
				by banner001
				nope, morrisons finest.
				Re: Fumes.
				Posted: Thu May 29, 2014 3:01 pm
				by KwakKwak
				Just found the problem, bloody tank edge is seeping beside the fuel tap, when I got the bike someone had bodged a leak fix, I sanded it down and JB welded and resprayed to seal it again, obviously JB weld ain't the answer without resealing the tank internally.
Unless Superplus eats through JB weld and 95 doesn't.
Any other products that will seal externally without having to coat the inside of the tank???
				Re: Fumes.
				Posted: Thu May 29, 2014 3:17 pm
				by KwakKwak
				Chicken?? not with electrics
Just saw PC.7 epoxy paste, anyone heard of it, seemingly has no equal, although they would say that.
				Re: Fumes.
				Posted: Thu May 29, 2014 3:18 pm
				by CaNsA
				Buy a non leaking tank from ebay.
The amount of time, effort and cost of repair will justify the cost.
fucking pikey.
				Re: Fumes.
				Posted: Thu May 29, 2014 3:23 pm
				by KwakKwak
				CaNsA wrote:Buy a non leaking tank from ebay.
fucking pikey.
My psychic powers are still working, cos I knew you were going to suggest that
				Re: Fumes.
				Posted: Thu May 29, 2014 3:34 pm
				by banner001
				Re: Fumes.
				Posted: Thu May 29, 2014 4:30 pm
				by KwakKwak
Have the Kreem set sitting here for another project, sameish stuff, replacing the tank is the obvious answer, but means spraying etc, probably.
I dropped my lid on the tank and dinged it and was about to add a hide the dent sticker over it, least of my problems now.
Might go for another temp fix as the bike is due out on a long run soon.
As its out of sight my "pikey" fix could be some fuel resistant resin/glue with fuel resistant ptfe tape covered in more resin.
OR take cargo up on his herin witnessed kind offer of fixing it for me, whilst I stand well out of the way.........again.
				Re: Fumes.
				Posted: Fri May 30, 2014 12:17 am
				by CaNsA
				Ask this guy how buggered his tank is...
viewtopic.php?f=179&t=16061
				Re: Fumes.
				Posted: Fri May 30, 2014 2:26 am
				by KwakKwak
				I'll take buggered on face value, my tank is perfect in every way, if you ignore the fact it can't hold it's liquor.
Should also have asked you banner if you had used that slosh stuff from your link above??? Any good???
I will also be investing in a fire extinguisher, seriously the fumes in my garage are bad, miscalculated draining the tank, had a slight overflow issue, ciggie anyone???
				Re: Fumes.
				Posted: Fri May 30, 2014 8:55 am
				by banner001
				KwakKwak wrote:I'll take buggered on face value, my tank is perfect in every way, if you ignore the fact it can't hold it's liquor.
cant say i have, but there are several types of this stuff on the market, my bikes near-mint - i would just buy a second hand good tank and get it sprayed, if you need decals im getting some from (
http://www.sunrisegraphics.co.uk/) so ill let you know how they turn out.
				Re: Fumes.
				Posted: Fri May 30, 2014 5:30 pm
				by KwakKwak
				banner001 wrote:cant say i have, but there are several types of this stuff on the market, my bikes near-mint - i would just buy a second hand good tank and get it sprayed, if you need decals im getting some from (
My bike is near mint too you cheeky git
Do update on the sunrisegraphics quality.
Have just ordered that slosh stuff as a temporary, or if I'm lucky permanent fix, will be on the lookout for a tank no doubt.
JB weld is actually meant to be fuel resistant, the seepage is from an area where I was probably too liberal with the stuff.
Seems someone is keeping secrets -
http://www.amazon.co.uk/Cargo-QuikSteel ... argo+epoxy
				Re: Fumes.
				Posted: Wed Jun 04, 2014 5:45 pm
				by KwakKwak
				Managed to find a tank with only 600 miles on the clock, bloody thing is it came attached to this beauty
Defo no leaks.
				Re: Fumes.
				Posted: Wed Jun 04, 2014 5:52 pm
				Now that is THE way to fix a leaky tank.
