Is the fuel pump needed?
SeattleZXR
My Bike: Kawasaki ZXR400
Post by SeattleZXR »
I have a 1993 L model. I'm curious, since it's carbureted and not fuel injected does it really need the fuel pump? I have a lot of bikes with a lot larger displacement that work just fine without a fuel pump.
dave111
Re: Is the fuel pump needed?
Post by dave111 »
An interesting question, one i'd pondered on as well, its, not like the carbs feed inlet is much lower than the lowest part of the petrol tap, try it and see then let us all know?
SeattleZXR
I am taking mine to a dyno at some point so I'm gonna ask the experts there what they think
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Works 90% but does not run properly on full throttle at high rpm. If you want to lose weight or electronic install a vacuum fuel pump from mikuni or dellorto. they work fine on the zxr ;)
Zxr 400 SL - 130kg
SeattleZXR
Do you have a part number for the vacuum pump that work with the bike?
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Mikuni DF44-18
http://www.bsmkartsport.de/de/Benzinver ... klein.html
DellOrto P32
http://www.kartshop-birel.de/DellOrto-B ... e-P34-PB-2
I have the dellorto one installed and it´s in my opinion the better one but both will work fine. In Germany they´re available, don´t know if you can get them easily in UK.
Edit: They come with 6mm fittings instead of 8mm which the zxr has so you will need an adapter/ converter, too.
Zxr 400 SL - 130kg
SeattleZXR
Thanks for the links. I'm in the US so that makes things even harder to get but with the a part number I can usually find something over.
SeattleZXR
This looks like the correct unit but it doesn't refer to it as a P34
Does it look like the right one to you?
http://sharkshifter.com/zc/index.php?ma ... ts_id=1388
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Yes that´s it exactly, 55L/h!
Zxr 400 SL - 130kg
SeattleZXR
Does it hook up to the air box? I'm a bit confused about how to install it.
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
It has two holes for as fitting option but it´s light enough to hold its own at the carb.
Here you see how I fitted it:
http://www.pic-upload.de/view-28499896/ ... 5.jpg.html
http://www.pic-upload.de/view-28499897/ ... 6.jpg.html
http://www.pic-upload.de/view-28499894/ ... 7.jpg.html
Zxr 400 SL - 130kg
SeattleZXR
I'm sorry if my question wasn't clear.
I know:
1.one port is an inlet
2.one port is an outlet
3.where does the 3rd port hook up too?
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
Well as it is a vacuum pump it needs a vacuum^^ that's the third one. Put a Y-piece in the hoses below the rubbers and connect them to the pump. You can (almost) see it in the pictures ;)
Zxr 400 SL - 130kg
SeattleZXR
I think I understand where to hook them up now. Same ports that are used to sync the carbs?
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
exactly
Zxr 400 SL - 130kg
