L model carbs any different to h model
Posted: Mon Dec 11, 2017 9:35 pm
by Zxr400paul
Hi all, was wondering if L model carbs are different to H model carbs and if they are how can you tell the difference, thanks Paul.
Re: L model carbs any different to h model
Posted: Mon Dec 11, 2017 9:46 pm
by Miles
If I remember the L carbs are 30 or 32mm bore.
I think the H is 28/30.
Whatever the bigger one is L
Posted: Tue Dec 12, 2017 9:28 am
by Ewetea
The H had 98 main jets and N77C needles as standard, and the L had 95 main jets and N77S or N77R jets as standard. But both models had alternative main jets ranging from 92 to 102. Since the basic engine is the same for both models, it shouldn't matter which set of carbs are used because you will have to fine tune them for idle running and performance.
Posted: Tue Dec 12, 2017 9:58 pm
by Zxr400paul
Thanks peoples!
