				L5 Engine unknown pipes
				Posted: Thu Oct 26, 2006 9:35 pm
				by mart33uk
				Have just purchased an L5 UK engine to fit to my H ZXR400.Having read the manuals sorted that the engine will fit ok i have noticed that there is a pipe coming from just below the carb mounts on the left as you look from behind where as my H engine has a bolt in the same hole,and also on my H engine the carb mounts are connected by two pipes(end to end and middle to middle)the L engine has these pipes but they are not connected carb to carb they just have screws in the ends?
Anyone know what goes where.[/b]
				Posted: Fri Oct 27, 2006 6:46 pm
				i think the pipes you are talking about are for balancing the carbs mate, have you got any pics so we can confirm?
				Posted: Fri Oct 27, 2006 10:12 pm
				by mart33uk
				Will post some picts tomorrow.So these pipes carry air from carb to carb or fuel.
				photos
				Posted: Sat Oct 28, 2006 12:21 pm
				by mart33uk
				Can't figure out how to insert images so i have emailed them to you,maybe you can insert them for me.
Cheers.
				Posted: Sat Oct 28, 2006 2:52 pm
				Posted: Sat Oct 28, 2006 2:53 pm
				aren't these the connection pipes for the carb heater pipes?? take one of the bolts out  i think you will find water pours out.
				Posted: Sat Oct 28, 2006 3:11 pm
				by zimm
				they are the balance pipes for attaching vacuum guages to, they normally join 1-4 and 2-3, or just blank them off, dont connect them 1-2 3-4 etc , as the pulses will be off and affect the fuelling, the one in the middle of the pic coming from the head is for the carb heaters.
				pipes
				Posted: Sat Oct 28, 2006 4:03 pm
				by mart33uk
				Thanks guys,i will use the pipes of my other engine and connect 1-4 and 2-3.As far as the other pipe i will remove it and put in the bolt from the other engine i hope this will work ok.
				Posted: Sat Oct 28, 2006 9:34 pm
				looks like all the pipes are coming from the head to me
