Page 1 of 2
				Carb icing?
				Posted: Sun Oct 21, 2007 10:53 am
				by zxr_oli
				Receintly by bike has been running like a tractor, but it only happens when i leave work (10.30pm) after about 10 min of riding.
It is defo a fuel problem, so i was thinking it could be carb icing?
I have never experianced carb icing before so i just wanted to check
				Re: Carb icing?
				Posted: Sun Oct 21, 2007 11:27 am
				by zxr_oli
				Also, forgot to add, It runs like fine at say 2/3s + throttle.
				Re: Carb icing?
				Posted: Sun Oct 21, 2007 12:14 pm
				by zimm
				could be carb icing.. does yours have carb heaters ? if not they do work, get some UK spec carbs and plumb them in.
other possibility is a knackered o-ring /float valve causing the carb(s) to flood a bit
				Re: Carb icing?
				Posted: Sun Oct 21, 2007 1:41 pm
				by zxr_oli
				Havnt got carb heaters, as far as i'm aware.
Only happens at night, so wouldnt have thought it would be the floats.
				Re: Carb icing?
				Posted: Mon Oct 22, 2007 10:08 am
				by rene
				halfords do a thing called 'Dry Fuel' its ment to help with carb iceing.  Never used it myself but others have said it works a treat might be worth giving ago for the sake of a £5
				Re: Carb icing?
				Posted: Mon Oct 22, 2007 11:16 am
				by zxr_oli
				Will give some of that a try.
Spose it would be difficult to fit carb heaters?
				Re: Carb icing?
				Posted: Mon Oct 22, 2007 12:16 pm
				by zimm
				you'd need a set of uk (or other, but with the heaters) carbs (import ones dont have the passages for em) then some rubber pipe, and a couple of T pieces. so that you can plumb them in to the cooling system... its fairly simple.. done the same thing on Emma's ZX-4 as that suffered really badly a couple of winters back.
				Re: Carb icing?
				Posted: Mon Oct 22, 2007 12:24 pm
				Mines and import and has them
				Re: Carb icing?
				Posted: Wed Oct 24, 2007 4:51 pm
				by zxr_oli
				Bought some Wynn's Dry Fuel.
It says empty entire contents into tank, but i assume this would be for a car? (325ml)
How much should i put it?
				Re: Carb icing?
				Posted: Wed Oct 24, 2007 8:55 pm
				by zimm
				RobB wrote:Mines and import and has them
some do, some dont, depends on the bikes intended market .. think german ones did .. also a lot of imports that came over in the early days got uk carbs fitted by the importer..
				Re: Carb icing?
				Posted: Wed Oct 24, 2007 9:25 pm
				Hmmm, always assumed it was imported from Japan,  maybe not then. It had a KMH speedo but then i think most european countries have them. Guess ill never know....
				Re: Carb icing?
				Posted: Wed Oct 24, 2007 10:21 pm
				by carsounds_dan
				is there a write up on how to fit the carb heaters? or where to "splice into" the cooling system?
mines got the carb-heaters fitted but theyre not plumbed up at all
dan
				Re: Carb icing?
				Posted: Wed Oct 24, 2007 11:09 pm
				RobB wrote:Hmmm, always assumed it was imported from Japan,  maybe not then. ....
my bikes imported from france
				Re: Carb icing?
				Posted: Thu Oct 25, 2007 8:30 am
				I think my 7R is from france, some of the writing on a badge on the frame appears to be french.
				Re: Carb icing?
				Posted: Sat Oct 27, 2007 4:53 pm
				by carsounds_dan
				RobB wrote:I think my 7R is from france, some of the writing on a badge on the frame appears to be french.
what makes you think that? does it translate to "surrender whenever possible"
