need help with fuel lines
Posted: Mon Jun 16, 2008 12:57 am
by pzofsak
I recently got this project bike (h1) and there was no fuel pump or fuel lines. I got the fuel pump but am having a bit of trouble figuring out the layout of the fuel lines. Can anyone walk me through what goes to what?
Re: need help with fuel lines
Posted: Fri Jul 11, 2008 3:59 am
by pzofsak
OK I got the fuel pump and tap side figured out but there is one thing left I need to know. Where does the tube from the right side of the tank go? There is a nipple on the bottom right side of the tank, I noticed in some photos that it has a rubber tube attached but I don't know where it goes. Any help will be appreciated.
Posted: Fri Jul 11, 2008 4:28 am
by zimm
fuel system,
pipe from fuel tap on tank to filter
filter
pipe from filter to inlet on pump
pump
pipe from outlet on pump to carbs
carbs
the "nipple" on the bottom right rear corner of the tank is a breather/drain that comes from under the petrol cap and runs inside the tank, any rain/excess petrol that ends up by the cap drains out of this, it "should" have a bit of tube bout 2 foot long attached to it and exiting down below the rear brake pedal or somewhere.. just so its not pissing all over the electrics/frame, but it doesnt really matter.
