SOLVED: Conking out on me :(
Posted: Fri Oct 31, 2008 7:19 am
Hi peeps,
Since this shitty weather has come to england my bike has been running like toad. Basically when I'm going down the gearbox from coming off an A or M road (slip road) when I come to a stop, the bike just dies. Also happens when coming to traffic lights. Everytime I come to a stop basically. I've turned to mixture screws from 3 to 2 1/2 and it's still doing it
SHe doesn't like to idle either, the only way I can get it to idle is to give it some revs then it will idle nicely again.
TBH i think It might be the battery because when I'm coming down the gearbox it sounds like the plugs aren't even sparking. Weak spark maybe due to fooked battery but I'm not 100% sure. mid range and top range seems to be fine. I adjusted the float heights to 11mm from 16mm
(haven't touched the floats since I got the new engine.) Also splutters ALOT at 4k rpm. I've taken the crank breather pipe off and it's got blobs of water in it. The airbox is swimming in fuel possibly from the fuel spitting out the carbs? Since I've had this bike it's been nothing but hassle. I've recently replaced the inlet rubbers from the L2 to L3 the ones with the rubber O-Rings. They are done up nice and tight and as far as I know aren't leaking as they are such a better design then the L2 design.
Any ideas would be great as I'm ready to throw the bike in the biffa!
Regards
RIch
Regards
RIch
