ZXR 400 H1, Overheating please help
ZXR400PROJECT
Re: ZXR 400 H1, Overheating please help
Post by ZXR400PROJECT »
adamm1704 wrote:The mph stickers are just a refrenece so you dont end up speeding. And its up too you. If you wanna save some money and take the pin out then do that but be carfull not to damage the internals of the clocks. If you wanna play it safe and have your speedometer and odemeter reading in mph then buy the mechanical converter.
n because ill put that converter on the speedo will i have to put a resistor on the ecu as i can only rev to 12500 n will only do 125 mph ???
adamm1704
My Bike: Zxr400 H1
Post by adamm1704 »
No you wont have to mess about with resistors. as your not actually changing the restriction system itself your just altering the speedo needle as it will never reach the activation zone for the restriction. If that makes sense :S. you should be able to rev it to the normal limiter and hit the 140 mph mark ;)
ZXR400PROJECT
adamm1704 wrote:No you wont have to mess about with resistors. as your not actually changing the restriction system itself your just altering the speedo needle as it will never reach the activation zone for the restriction. If that makes sense :S. you should be able to rev it to the normal limiter and hit the 140 mph mark ;)
My bike only revs to 12500 in every gear even now ill be in top gear doing 10,000 revs doing 112mph no more ? n whats the point then of people paying for a uk ecu or m box like £40 for ecu or £80 for a m max box when u can just pay £25 n have it top speed. you still have to do something with the ecu cuz if i leave it as it is ill only do 12,500 if i derstrict it ill get 14,500 revs how will i do that then thx
ZXR400PROJECT
whats a odemeter ?? n forgot to say my bikes a bit crap on acceleration feels juggy to start with could that be due to the overheating if it is the head gasket ? n do you know any one in kiddy area or 30 mile radius that can do my head gasket n thermostat NOT A SHOP to much money want a interdependent mechanic thats good but cheap thx
adamm1704
My Bike: Zxr400 H1
Post by adamm1704 »
When you rev the bike in neutral the rev limiter kicks in at 12.5k revs?
adamm1704
My Bike: Zxr400 H1
Post by adamm1704 »
If i was you id get it compression tested to see if it is the head gastket or not. You can pick up a compression tester kit for cheap
http://www.ebay.co.uk/itm/PETROL-ENGINE ... 2a1be2bc06.
A compression test will help alot :)
Oh and odemeter is the milage counter
ZXR400PROJECT
adamm1704 wrote:If i was you id get it compression tested to see if it is the head gastket or not. You can pick up a compression tester kit for cheap
My bike only revs to 12500 in every gear even now ill be in top gear doing 10,000 revs doing 112mph no more ? n whats the point then of people paying for a uk ecu or m box like £40 for ecu or £80 for a m max box when u can just pay £25 n have it top speed. you still have to do something with the ecu cuz if i leave it as it is ill only do 12,500 if i derstrict it ill get 14,500 revs how will i do that then thx ??? , just looked at my bike looking past the forks where the drain plugs are n all round there is coolant n oil its NOt comming from the drain plugs looks higher up ? can i use rad flush while the rad is still on my bike n put a water hose in the top of my rad n let it run for 10min get the rad all clean while the rad is still on me bike plz answer all
Locked
