Overheating! please help
Posted: Tue Aug 07, 2012 6:42 am
by v1nn13
Hey guys, i bought my H1 back in February from chesterfield and rode her all the way home to Ashford (around 220 miles) without missing a beat. She behaved herself every day until summer came round (bout mid-June time) when one day, on a nice ride, i noticed the temp was climbing dangerously, so i pulled up to let her cool off and to check her over. However, I noticed when the engine was killed, she dumped about a liter of coolant onto the floor which meant the tank had emptied the time she had cooled again. when i got home i filled her up, bled the system and tried again...still same problem. So i decided to change the Rad cap as a cheap starting point...still same problem. Changed the Radiator itself...still same problem. The system has been pressure checked and no leaks are obvious. Starting to fear for a head gasket change as this is only mode of transport at the moment, no signs that is has gone though. No mayo in oil, No white smoke emitting from exhaust and engine runs like a dream.
Anyone had the same problem and found the cause. Help would be very much appreciated as cant be doing with her off the road for weeks on end.
Re: Overheating! please help
Posted: Tue Aug 07, 2012 7:24 am
have you checked the thermostat? what colour was or is the coolant?
Posted: Tue Aug 07, 2012 9:59 am
by Tirpitz
Is the water pump working? Sounds a bit odd to me that it overheated while you were on the move yet you have no symptoms of HG problems. I just wonder whether the pump is actually pumping. It's easy enough to remove and you can then inspect it and the drive to it to make sure everything is turning and intact.
Posted: Wed Aug 08, 2012 8:13 pm
by tobomoto
mine had exactly the same problem. i changed all the above plus the oil cooler and lines, water hoses, header tank, thermostat. it turned out to be the head gasket had a split in it so it was letting coolant out but not mixing it with oil, if that makes sense? i got it cylinder pressure checked and one was out- i think they were 90,92 82 90 ish or somthing. it turned out somone had put non standard pistons in it and had done the head bolts up in the wrong order.
Posted: Wed Aug 08, 2012 8:23 pm
by R P Corse
possibly an air lock of some sort
Posted: Wed Aug 08, 2012 8:45 pm
by banner001
tobomoto wrote:mine had exactly the same problem. i changed all the above plus the oil cooler and lines, water hoses, header tank, thermostat. it turned out to be the head gasket had a split in it so it was letting coolant out but not mixing it with oil, if that makes sense? i got it cylinder pressure checked and one was out- i think they were 90,92 82 90 ish or somthing. it turned out somone had put non standard pistons in it and had done the head bolts up in the wrong order.
i think they were 90,92 82 90 - thats not 1 out...thats all 4 out...
Posted: Mon Aug 27, 2012 11:13 pm
by tobomoto
i cant really remember now, it was back in 2000! i really didnt think much of the place though but at the time they were the only place near me that had a dyno machine. cant bellieve they still have a race team going. they were as unhelpful as anything, just kept going on about doing my head gasket but didnt like it when i said 'if you dont know roughly whats wrong with it, still, they relieved me of £98 so it was all good (for them at least)
Posted: Mon Nov 26, 2012 9:16 pm
by v1nn13
Problem was either head gasket or thermostat/seal, although cant be sure as replaced the thermostat and thermostat seal at the same time as the head gasket :/...she's all better now
