NEED HELP ABOUT TOP END!!!
Posted: Fri Feb 19, 2010 5:14 pm
Heya all! just a couple of questions.... im in the middle of stripping my old ZXR 400 L8 engine and i have got two problems.
n01 - How can i break the oil pan gasket seal to remove the pan? ( i have tryed the rubber mallet aprouch with no luck )
no2 - On the top end where the cam cogs are were the chain goes over the top is a metal plate that looks like some sort of tensioner, anyway to the point there are two allen key bolts that sequre a metal bar with a rubber guide under it and i need thoes two bolts out to remove the cams and chains. I have tryed everything with no luck! can anyone suggest anything to thease problems?
Anything would be a great help!!
(btw i am not looking to adjust any timing etc, just a complete strip down to sell the good parts, if anyone can recomend which parts to keep together or sell individualy that would also be very useful.)
Jake
Jake
