Race engines and F3 engines
Posted: Tue Mar 19, 2013 7:45 am
				Over the years I have bought a fair stack of ZX lumps from the ZX-4 ~ M6
Some have been described as ex-race F3 engines but once opened they were just normal SP motors prepared for racing with lockwire , thermostat removed , SP cams dialed in and the occasional starter motor blank.
Recently I bought another SP motor described as being used in races and was started up before removing from bike for storage. Sellers photos didn't make it look pretty and neither do mine lol
Generator cover is plain so a sure sign it's a J1 or J2 , however it has stubs for FCRs and even the F3 J1 used CVKs with bellmouths and airplate , startor motor is removed and has the kit blank plug fitted , generator cover off and no flywheel or windings and the kit plug for the electrical lead exit fitted even the sprocket cover has been modified.
Inlet tracts and exhaust ports have been polished
  and block still has F3 manifolds bolted into it ( I have an F3 system so know what it and the springs look like )
Cam cover off reveals it has F3 cams installed too
  ( I have a set I can compare against )
Pulsar cover off to spin the cams around to check lobes reveals a kit rotor
It also has J stamped on the block
Plugs out and some old school Champion race plugs in there:
Just keeps getting better
So this is the first motor I have seen to have been so far fully tricked out for racing , I suspect when I remove the head it will have had the F3 modifications done to the cylinder walls and head , with the rotor drilled I wouldn't be surprised if the crankhas also been balanced and I can check if it has an F3 gearbox as I have one of them in the store already.
I am all for stripping it down and fully overhauling but another part of me is " buggar that! " - fit nicer casings, bung my race generator into it , check the clearances and get it into a bike and try it out and power check it. Then at some point in the future once I've built the F3 motor I have all the parts for, replace with it and then go through this one like a dose of salts - will report back on my final decision
Anyhoo, delighted with my purchase what a result - only taken 6yrs to get an actual F3 engine or from a racer running at a professional level.
