Starter clunking and not engaging
Posted: Thu Mar 06, 2014 6:30 pm
When trying to start my bike 9 times out of 10, I get a clunking and grinding noise coming from the starter motor, followed by the sound of the starter spinning (engine not turning).
every few attempts though, something seems to catch and it will turn the engine over (enough to start it), although it sounds really clunky when it does and if it needs a lot of cranking to start (i have carb problems) it clunks out of contact after a few revs and starts clunking and spinning again.
Battery is fully charged, charging system ok, relay ok and the noise is definitely coming from the engine.
I've replaced the starter motor, and get the same problem. It used to not occur so frequently but now it happens almost every time.
I've just taken of the alternator cover and the starter gears seem to be fine, no wear, no teeth missing.
Possible this could be a problem with the starter clutch, im not 100% on how it works? or anything else?
thanks.
thanks.
