valve clearances
richyrd5
My Bike: 400h
valve clearances
Post by richyrd5 »
Where do you check between...400h..lobe and rocker or shim and rocker.??my nc30 is the same as near as in valve train and that is shim and rocker(even though Haynes book of lies says lobe and rocker!)..thanks winks
Dominik
My Bike: Zxr 400 L3
Re: valve clearances
Post by Dominik »
Between lobe and rocker is right if you go for 13-17/16-21 clearance.
In the kit manual there are bigger clearances mentioned which should get measured between shim and rocker
Zxr 400 SL - 130kg
richyrd5
My Bike: 400h
Post by richyrd5 »
:smt001 excellent.thanks dom biggrin
