head gasket gone on mi 400l
chris 400l
My Bike: zxr 400 l
Post by chris 400l »
Any body know where i can get a manual head gasket gone on my baby i know what i doin just need tecnical data ie sequence of bolts to torque first on head and also what nm settings cheers fellow zxr ers
Miles
My Bike: ZXR 400 L3
Re: head gasket gone on mi 400l
Post by Miles »
zxrworld.co.uk
Has the L H & racing manual all there as well as loads of other information
chris 400l
My Bike: zxr 400 l
Cheers miles but getting hold ov em like rockin horse poo
Miles
My Bike: ZXR 400 L3
Post by Miles »
Just go to the website and download them as pdf files or look on eBay they come up often enough.
Dominik
My Bike: Zxr 400 L3
Post by Dominik »
The order to tighten the bolts is engraved in the cylinder head. Torque is 25nm I think. Losen the bolts in the opposite order starting with the outer ones. Be careful with the cam covers and lose the bolts step per step over cross.
However the linked manual has more detailed information so just give it a look...
Zxr 400 SL - 130kg
chris 400l
My Bike: zxr 400 l
Thanks dominik i know how to do it am very apt just needed torque settings but cheers for info
fstarocka
Post by fstarocka »
Yes 18ft lbs / 25nm. You undo in a criss cross spiral towards center and install from center outwards in two or 3 steps.. Don't forget the 6mm bolt inside timing hole.. And the oring seal in head at front right cam chain cover (2 hex bolts), it's the primary oil feed to the cams..
Sent from my SM-G900M using Tapatalk
