mornin all, quick question, i cannot find anyinformation about timing up the engine (l3) jus wondering if it is the same as the h model as i have that in a manual.
rob
cam timing
- toykaboy
cam timing
you bend it you buy it!
the L model manual is just a supplement and is supposed to be used in conjunction with the H model manual, it states in the specifications in the L manual the timing spec but i think you need to go by the H manual.
i only ever done the timing when the engines have been out the bike, the first time i have done it with the bike in situ and by god its a nightmare, trying to align the timing mark considering you really need a mirror to line it up due to the frame being in the way!
Or has anyone got a handier tip to align it perfectly so you can see the timing mark properly while engine is still in the frame, without loostening the front engine mounts and pushing the engine forwards a bit
