some questions about engine
Posted: Mon Jun 12, 2006 10:30 pm
Hy!
I am renovating my zxr-400, and i need to know how strong must i turn the head bolts? They sad to me at the service, i should first do 1,5kg and after a while 2.5kg. Is it clever to run the bike in the middle? Some say that i should, that matirials must lay down... And the others i should not, but i dont know why? If i wanted to run the bike, i must put it all together and this takes a lot of work... Than agein all apart and turn the bolts on 2.5, and put it al together agein.
What should i do? I turned the bolts now on 2.0kg and put the bike together. Is it cool 2.0kg, what can happen if i dont do it 2.5kg? Now the engine is running, but on very high RPM... Is it posible, that it runs higher becouse the had is lower for 0.1mm (if i didnt simply mess up something with the carbs...) ? I was forced to lower it, becous it was not straight. Must i do some settings with the valvs and the valvs springs becouse of it?
That should be all witch bothers me... Understand that it is my first 4-stroke projeckt, and i do it all alone! And sorry for the English, im from Slovenia...
By
By
