OK guys, ive built a slippy clutch for my H model using an L model basket and cover that i had but when ive come to install it i found i didnt have the springs or bolts, i suspect the springs are the same length on the H and L models but the bolts are definately different, does anyone have an "L" model cliutch in bits at the moment that they can check some measurements from for me.
Cheers Darren
Edited by CaNsA.
Reason: Bad idea to post your number on a public forum.
Clutch spring difference between H & L models
The Gatekeeper
- My Bike: ZXR400, 2001 ZX6R,
- Location: York, North Yorkshire - England oldest roman city
If at first you don't succeed, try doing it the way you were told in the first place !
The Gatekeeper
Re: Clutch spring difference between H & L models
No sorry spring free length is there but not the bolt length, thanks for the reply though
ZX4R-F3
- My Bike: 1988 ZX400-F3
Bolt and springs have different part numbers, L bolt slightly longer about 5mm.
Yes I do have to much time on my hands (at work).
[b][color=#FF0000]If your not living on the edge, then your taking up to much room.[/color][/b]
The Gatekeeper
What a great reply, thank you so much !
I will also need the recessed washer part 14020
Do you have a contact number of the company I can order them from
Cheers Darren
Cheers Darren
If the springs are different then the bolt length is bound to be different................
I belive the company you need to speak to to get these parts is called Kawasaki................or at least one of their dealers
The Gatekeeper
To be honest cargo, if you can't say anything that's not sarcastic STFU !
yeah your so right.....................but then I'm not the one who needs to ask stupid questions.
The Gatekeeper
Well do me a favour, don't ever attempt to answer one of my "stupid" questions ever again ..I..
