Re: Clutch Cable Holder Bolt dropped down
Posted: Fri May 20, 2011 8:01 pm
Thanks alot for the info...
Did you mean top right corner of the pic??
That part is the only thing that could lock into the actuating rod. I see what you mean now about locating into groove and twisting.
BUT - when I pull this pin, I would expect it to be elastic ie pull back when I let go. Am I right? Otherwise how else would the clutch cable hold tension?
When I pull mine however, there is no tension or elasticituy. It just loosely pulls out, then I have to push it back in again!!!
Surely this cant be right?
