cable or clutch
Posted: Tue Mar 25, 2014 1:27 pm
by lacoscb
Hi all having problems with the clutch replaced cable and now the clutch only disengages when the leaver is right on the bar and the cable has no more adjustment ????
Re: cable or clutch
Posted: Tue Mar 25, 2014 1:58 pm
by CaNsA
Where are you adjusting it?
There is one adjustment on the lever, another just in front of your right foot.
Re: cable or clutch
Posted: Tue Mar 25, 2014 2:56 pm
by lacoscb
Adjusted it from both ends cant get any more slack out of the cable
Re: cable or clutch
Posted: Tue Mar 25, 2014 4:46 pm
by banner001
you got the right cable? from memory the H and L are different lengths. (or is that throttle cables?)
Re: cable or clutch
Posted: Tue Mar 25, 2014 5:18 pm
by lacoscb
Yer got cable from wemoto , tis like the control arm has to move more than the cable will let it
Re: cable or clutch
Posted: Thu Mar 27, 2014 4:59 pm
by lacoscb
Do all the l models have the same length cable
Re: cable or clutch
Posted: Thu Mar 27, 2014 6:13 pm
by CaNsA
Yeppers.
Re: cable or clutch
Posted: Thu Mar 27, 2014 6:47 pm
by lacoscb
Thanks so it must be the clutch then
Re: cable or clutch
Posted: Fri Mar 28, 2014 12:03 am
The L2 I'm currently working on has been fitted with some kind of NON Kawasaki after market clutch cable.
It is defo too long and the adjustment cannot take up the slack. Which seems to me to describe your problem exactly.
Just saying like
Re: cable or clutch
Posted: Sun Mar 30, 2014 4:20 pm
by lacoscb
Is there a return spring , as has virtual no return on the control arm
Re: cable or clutch
Posted: Sun Mar 30, 2014 5:51 pm
No
Unless of course you consider the clutch springs to be "return" springs
Re: cable or clutch
Posted: Mon Mar 31, 2014 4:17 pm
by lacoscb
So what returns the leave then
Re: cable or clutch
Posted: Mon Mar 31, 2014 4:38 pm
by ManxMan
I think it's the clutch springs
Re: cable or clutch
Posted: Sat Apr 19, 2014 8:35 pm
by Bobby Dazzler
Did you find a solution to this as I have exactly the same problem.
Re: cable or clutch
Posted: Wed Apr 23, 2014 10:53 am
by Miles
Is the rotor arm placed correctly?
