KBATL swap.
Dom-r30
My Bike: CCM R30 ZXR400
KBATL swap.
Post by Dom-r30 »
Hi all,
Has anyone swapped and fitted the KBATL clutch to the H1 engine?
If so is it just the Clutch drum, steels and pressure plate required? As the KBATL clutch assembly I have has a broken basket (2 fractured fingers)
Baskets look the same but I'm trying to confirm before going too far.
Dom
Miles
My Bike: ZXR 400 L3
Re: KBATL swap.
Post by Miles »
Not sure, I think the bottom end is the same on the H + L but have a look at the part numbers
Dom-r30
Re: KBATL swap.
Post by Dom-r30 »
Been right through the 'clutch section' one post hints at being able to do the swap but doesn't confirm in detail about the baskets.
Been through microfiches and workshop manuals, parts numbers are different but that doesn't always mean incompatible. :smt017
Dominik
My Bike: Zxr 400 L3
Re: KBATL swap.
Post by Dominik »
If you're on it, would you mind to weigh both clutches? I'd be interested in how much the h1 one might be lighter
Thanks!
Zxr 400 SL - 130kg
Dom-r30
Re: KBATL swap.
Post by Dom-r30 »
H1 clutch no clutch basket or centre pin, butt all steels, drum, cover, bolts, springs, nut and washers 1451grams
H2 as listed above 1951grams
Hope this helps with your weight saving quest.
And no H2 internals require a centre lip machining on basket to safely fit in a H1 basket.
Dom
Dominik
My Bike: Zxr 400 L3
Re: KBATL swap.
Post by Dominik »
Thanks for the information mate!
If your interested in swapping your h1 one for a L model one contact me ;)
Zxr 400 SL - 130kg
