clutch
kion
My Bike: zxr400
clutch
Post by kion »
dunno if this is with all zxr, mayb just mine but compaired to other bikes the zxr clutch is realy toad, like betime ive released it am doin 5-10 mph unless i give loads of revs, like on other bikes betime uve released the clutch ur doin 20mph, feels dead dull as well with no pullin power???
ride with pride
Re: clutch
Thats a really crap explanation mate :smt005
Not sure what 'betime' means? before?
Im guessing what your trying to say is you have to change into 2nd gear at quite a low speed, whereas other bikes are going alot faster before they have to change to 2nd gear?
If so, then thats pretty normal, other bikes will have very different ratios in the gear box than the ZXR. You could also try reving it higher ;)
kion
My Bike: zxr400
Re: clutch
Post by kion »
lol toad, betime= by the time.i think i may gear down the sprokets, would that help, no its just the clutch its very week, the zxr has a tall first gear.
how fast are u goin on ur 750 betime uve released the clutch,
ride with pride
Re: clutch
On my 750 i darent let the clutch out too quick incase it flips, from a standstill anyway :d
Do you have an SP model? They have very tall first gears as far as i remember.
Still not sure what your getting at :S Im guessing you cant slip the clutch long enough to pull off smoothly? So its just 'grabbing' at low speed, check your oil make sure its the right level and also that its not old old oil. If they are ok, you may just have knackered clutch plates.
Re: clutch
If the clutch plates are good, then they get off the mark as fast as you can keep the front end down....
But they do seem to suffer a bit from clutch slip...which yrs may be?
Xphyral
Re: clutch
Post by Xphyral »
it's a 400, power starts a lot higher in the rev range. give it more revs, spend a little longer letting the clutch out. there isnt much power at the bottom end so if your not revving it enough and finishing your clutch slip too early your going to bog it down, and by the sounds of it (5-10mph) thats what your doing. it's not a 750, it's not a 600 it doesnt have as much big bang for the bottom end torque so your gonna have to give it a handful and learn to balence it on the clutch properly.
Re: clutch
my clutch works mint. in fact the 400 clutch is way better than me 600 :smt017
Re: clutch
your not slipping the clutch by the sounds off it, i could let the clutch fully out on my zxr at 10mph odd or slip the clutch up to about 40 odd for the fastest possbile start
dont worry about damaging the clutch, motorbike clutchs are covered in engine oil and made to be slipped loads
Re: clutch
superman wrote:my clutch works mint. in fact the 400 clutch is way better than me 600 :smt017
Does the 600 not have a slipper clutch?? Or is yours an older one? Ive heard some great stuff about those slipper clutches.
Re: clutch
the zxr has a slipper clutch but its called a "back torque limiter". All a slipper clutch dos is if you go down the gears to quick it slipps the clutch insted of locking the rear
