Clutch
MillaMeter
Clutch
Post by MillaMeter »
Hiya peeps,
I recently fitted a new clutch kit because the old springs that was in the bike were like 5mm shorter then the new ones. Anyway... I've adjusted the clutch to max down by the engine hoping it would give me loads of room at the lever for play. Wrong! the clutch cable adjuster at the lever is also at it's max. Surely installing a new clutch springs will give me more play right?
Anyone else got this problem or anyone else know what the problem may be?
Rich
zxr_oli
My Bike: Daytona 675
Re: Clutch
Post by zxr_oli »
Tightening the adjusters will take away the play. Loosen the lever adjustment fully, then adjust it at the engine so you have a few mm or play, lever adjustment is for the fine adjustments.
Difference length springs wont effect the play, but will affect how hard / easy it is to pull the lever.
MillaMeter
Re: Clutch
zxr_oli wrote:Tightening the adjusters will take away the play. Loosen the lever adjustment fully, then adjust it at the engine so you have a few mm or play, lever adjustment is for the fine adjustments.
Thats the thing though, the adjustment at the engine is at it's max, so is the the lever end and the clutch is no were near where I like having it.
Regards
Rich
zxr_oli
Re: Clutch
Post by zxr_oli »
Tightening them will remove the play, loosen the lever play, and adjust the engine 1 so it has just a little bit of tension then work from there.
Ballsout Racing
Re: Clutch
Post by Ballsout Racing »
The bracket that holds the adjuster at the gearbox end can bend fairly easily, just bend it a little to give you adjustment you require :smt002
parby81
Re: Clutch
Post by parby81 »
Are you sure you're clutch cable has stretched beyond its working limit?
MillaMeter
Re: Clutch
MillaMeter wrote:Thats the thing though, the adjustment at the engine is at it's max, so is the lever end and the clutch is no were near where I like having it.
Regards
Rich
