Adjusting Clutch
Posted: Sun Oct 23, 2005 4:35 pm
by kb-zxr
How do you adjust the clutch cable slack at the engine end (not lever end) as mine is really bad. Put it in gear with the clutch in and the bike bounces a bit like its trying to bite.
Posted: Sun Oct 23, 2005 7:38 pm
by zxr400er
At the bottom cable passes through the arm it pulls, there is a nut either side of the arm. You can move the cable through by tighten up.
Posted: Mon Oct 24, 2005 12:08 pm
by kb-zxr
Thanks, all done now
Posted: Sun Jul 02, 2006 6:26 pm
by carlfzxr
is clutch wear quite common? My zxr has 16k on the clock I`d i`ve run out of adjustment at the top end already.
Posted: Mon Jul 03, 2006 9:26 am
is the clutch slipping?
Posted: Mon Jul 03, 2006 10:31 am
by Bikerz
New clutch cable? my zxr400 done sod all miles but iv put a new clutch cable on. about 15,000kms i think shes on
Posted: Mon Jul 03, 2006 11:12 am
i remember putting a new cable on my zxr400 and it was longer than the cable i took off, in the end changed the clutch plates.
Posted: Thu Jul 20, 2006 9:14 am
by jason_rmh
I have a brand new clutch cable and it too seems too long. The cable is fully adjusted at both ends???
Is changing the clutch plates neccessary, and is it hard to do?
I have a spare engine to take bits off if need be.
Jason
Posted: Thu Jul 20, 2006 10:04 am
by aposegil
mate changing clutch plates piss easy job
see my two post took me about 30 mins and i never done it myself thanx to the help from guys on here and the manuals here
look at the H model for the write up
