wheels and swingarms
chrisrowles
My Bike: zxr400 h1 project
Post by chrisrowles »
I have a H2 Swingarm to put into my H1 frame.
is there any difference in the wheel, spindle and or cush drive for a h2 wheel or will my H1 wheel go straight in?
noelb
My Bike: ZXR4H , H'Berg , BMW R12S
Re: wheels and swingarms
Post by noelb »
H2 spindle is bigger so leaves everything wheel related needed for the conversion. The swingarm opening widths are the same and I'm nearly certain the alignments (chain and brake) are the same as well so if you got a pair of spacers (1.5mm wall) to bring the smaller 17mm H1 spindle to fit the 20mm slots then you might be good to go. The H2 cush drive is the same as the L (and a lot of later Kwakers) and is a good bit lighter, if you're racing its worth looking for the wheels. Not sure of H2 wheels are the same as Ls though.
Hope this helps!
Noel B.
