zxr400l front wheel doesnt fit??
Posted: Mon May 25, 2009 10:19 pm
I'm sure this is an easy one for all you seasoned zxr400 lovers. I bought a spare set of wheels for my track zxr. Popped em in no props, an have used ok. The other day I decided to change the wheel bearings so set about dismantling them only to find a washer next to the bearing that isnt shown in the manual. Now with it removed the wheel is sloppy. Ive measured from the bearing to the outer of the hub and have found there is about 3-4mm difference between this and the original wheel. Upon closer inspection I notice slight differences in the wheel. I have concluded that they are zxr400H wheels and someone has bodged in a spacer at some point. Does this sound correct? Has anyone else swapped the wheels? I'm looking at getting a spacer specially made to solve this. ha anyone else done this and can you confirm exactly what size it should be? Thoughts please
