Siliconed cush drive
Posted: Sat Apr 09, 2016 3:20 pm
by Flatcap
Im about to paint a replacement wheel which has no sprocket &disc on it so began pulling the bits of the original wheel.Why, when the cush drive rubbers look good, did someone in the past stuff it all with bleedin silicone? Now I know no ones a prophet on here but is this a done thing?
Re: Siliconed cush drive
Posted: Sat Apr 09, 2016 8:00 pm
by Tricky
in the track day/racing world, rubbers are often siliconed in so that when you change from drys to wets (wheels), all you have to do is pull the sprocket carrier out without wasting time/messing about replacing the rubbers.
Posted: Sat Apr 09, 2016 9:54 pm
by Flatcap
Maybe its been tracked at some point then! Cant think of any other reason to fill it with that stuff
Posted: Sun Apr 10, 2016 12:46 am
by Miles
Unless it's some how to do with a worn Cush rubber and the previous person has tried to bodge it with silicone to take up slack...
Seems unlikely now I've read that back lol
Posted: Sun Apr 10, 2016 9:53 pm
by Tricky
Miles wrote:Unless it's some how to do with a worn Cush rubber and the previous person has tried to bodge it with silicone to take up slack...
its a possibility, ive seen worse bodges!
what's the condition of the rubbers Flatcap?
Posted: Mon Apr 11, 2016 2:09 pm
by Flatcap
They look pretty good with no apparent sign of splitting or cracking but I would have no idea it they shrink or not! Anyway, I have fitted them back in without the goo so will see how it is once I can ride the thing
Carbs are out having a clean at the moment
