I've recently adjusted my chain as it was as loose as Hilary Clintons nether regions before.
It's quite tight now with not too much free play, just a mil or two. However it's starting to make a squeaky noise as the bike moves. I've put oil on the chain but only when the chains cold as i'm unable to ride it at the moment. Will it cause damage if I run it like this or will the chain stretch and sort it self out after a good running and then oiling?
Thanks for any advice
