ZXR400 front discs, opinion required
Posted: Mon Sep 06, 2010 5:38 pm
Hello, im due to replace the front discs on my bike, one is warped and both are at 2.8mm ish!
Anyone rate these chinese discs on ebay,
http://cgi.ebay.co.uk/Front-Brake-Disc- ... 35ac2eec34
or
http://cgi.ebay.co.uk/Front-Brake-Rotor ... 1c14d39e37
the thickness of them is 5 and it states min thickness of 4.5mm, both of which are above standard discs, good or bad? either showing that these might be suspectible to warping after little use.
Also as you will see the first set it more 'hollowed' whereas the second set is clearly different, im a bit unsure of the correct terms to describe the discs!
Cheers Ross
or
Cheers Ross
