brakes
Posted: Sat Aug 18, 2012 3:57 pm
hi, was hoping someone here could help me figure out my brake issues, im using the bike daily so dont want to pull it apart untill im sure i have all the stuff to fix it to hand.
i have two issues, firstly the front brakes although fairly powerful have an intermittent snatching issue. not always there but often when applying the front brakes the lever feels stiff so pull it a bit harder and it loosens but the extra force used causes the front brakes to snatch on really hard, very annoying when your adjusting speed slightly and you nearly lunge over the bars. i have bought some braided front lines (not fitted yet) the pads and discs are ok.
im thinking this could be a piston or maybe the master cylinder sticking? has anyone had a similar problem and found out the cause?
ok problem 2 is the back brake is useless. when pressing the lever it travels way too far and hits its limit. does work some but barely. ok i thought, a quick bleed will fix it, but i only got fluid through the back nipple (awkward one) the outside nipple yielded no fluid. would this warrant a new caliper? or rebuild? i was thinking about looking for a replacement caliper on ebay but not sure i really need to replace anything as yet.
cheers.
cheers.
