brake fluid tubing
Deano2485
My Bike: zxr 400 l4
brake fluid tubing
Post by Deano2485 »
Anyone know where I can get some of the hose that connects the front master cylinder to the reservoir and what materials can be used
Re: brake fluid tubbing
sorry I haven't got a clue what materials you could use.
In my experience when it comes to something important like brakes it's best to use genuine Kawasaki parts
KwakKwak
My Bike: ZXR 400L9 2001
Post by KwakKwak »
cargo wrote:sorry I haven't got a clue what materials you could use.
You're right about my mind reading skills, cos I knew you were going to say that
Deano2485 wrote:Anyone know where I can get some of the hose that connects the front master cylinder to the reservoir and what materials can be used
any non-swelling plastic or rubber will be fine, use what HRC use on the rears if you want something a bit different...
http://www.ebay.co.uk/itm/Genuine-HRC-H ... 58a096675c
dont get the "pink" pipe, it allows some water vapour in, the green one is the one to go for.
ross46
My Bike: zxr 400 l6
Re: brake fluid tubing
Post by ross46 »
you can use tygfon hose, its what they use on the hrc mc deletion kit, cheap as chips aswell though cargo is right you can just get from cradley, but its £11.10
That HRC rear brake reservoir is intend to remain straight and upright or only a very slight bend.
Try to bend it to fit the front brake and it will likely kink
It is also a different bore if memory serves me right
But the WTF would I know
KwakKwak
Post by KwakKwak »
In a different post cargo stated every problem here is complicated and the answer even more complicated, point proved.
I'm not taking sides, or trying to wind anyone up etc etc, the tubing banner is suggesting could be the best stuff ever, I don't know, it may not suit, cargo could be right, I don't know, point being, in my position I would go for the OEM, safe in the knowledge it will fit perfectly and is without doubt correct for the bike, simple, no?
ross46
My Bike: zxr 400 l6
Post by ross46 »
I agree, I'm looking at replacing the tubing on my front master cylinder but removing the rear (think it looks better) so front OEM, rear use the tygon stuff but keep all the unit just Incase
