Looks like i f*cked the brake fluid change.
Posted: Fri Mar 13, 2015 10:35 am
hi,
wanted to do a full change of my brake fluid front and rear, so i followed what it says in the manual which is basically just to open the bleed valve and pump the lever till nothing more comes out (no topping up the reservoir)
took me a whole bottle of brake fluid through the front callipers and one side was still giving out a tiny amount of air bubbles. brakes are ok on the front but i think the lever is still spongey to be honest. and the rear, well now the pedal has absolutely no pressure in it all, it also took a whole seperate bottle and still had air coming out at the end.
feels like i did this in a particularly sh*tty way, bearing in mind i completely emptied the whole system, how can I make sure that the whole system is now full of fluid, master cylinder etc included?
