Piston 'ceramic type' Inserts
julesfay
My Bike: Ninja Jules
Post by julesfay » Sun Aug 30, 2015 12:04 pm
What are 'ceramic type' inserts in the pistons for?
Mine are crumbling and I cannot find any replacement inserts or complete with piston housing, are they needed as they stand slightly proud of the end of the metal part of the piston?
banner001
Track day God
Track day God
My Bike: ZXR400 L4
Re: Piston 'ceramic type' Inserts
Post by banner001 » Tue Sep 01, 2015 11:59 am
its not an insert per se, but a physical part of the piston.
you have two options, if available for the year of bike buy OEM from a kawasaki dealer, or buy the non-OEM ones off ebay/wemoto etc... they work perfectly fine and are easier to remove for repair as you can use standard brake piston pullers to remove them.
UK ZXR 400 L4
UK ZXR 400 L3 track bike
Tirpitz
My Bike: Kawasaki ZXR400L4
Post by Tirpitz » Sun Nov 22, 2015 2:07 pm
They are for heat dissipation. FWIW Kawasaki do not recommend using OEM sintered pads on pistons without a heat dissipating insert as it could lead to excessive brake squeal - so they say.
Hel braided hoses
Pirelli Diablos
Ohlins steering damper
A16 carbon fibre exhaust can
Nitron Sport shock
