Aftermarket Levers?
SamZX
My Bike: Kawasaki ZXR400 L3
Aftermarket Levers?
Post by SamZX »
I was thinking of getting some sexy Aftermarket levers for my ZXR400 L3 model, has anyone done this already? and if so which make would you recommend? so far after doing some research the only brand I can find that claims to support the ZXR400 is Pazzo. Has anyone had any experience with them? also... They do operate the brake light switch properly don't they? lol, as there obviously designed for track use; they look like they do...
Thanks in advance!
Jack Of All Trades... Master Of F*ck All
SamZX
Re: Aftermarket Levers?
Post by SamZX »
Sorry for the double post... I just noticed I think this topic should be in the ''Your Tuning Questions'' bit, not here... Sorry about that.
will#224
My Bike: L1 racer
Post by will#224 »
Have a look at the performance technology flip up levers. About £35 each
bendog66
Post by bendog66 »
only just seen this. The levers don't operate the brake light, the little switch the levers rest on do, so yes, they will. However, Pazzo don't make them specifically for the ZXR400. You can get some to fit though...
The front brake lever from a GSXR will fit although the marked part has to be replaced with one from a bike they do make them for (i used a zx636 one, as the side stand sensor is the same fitting) to fit the clutch lever:
