Rear Shock Upgrades - What fits?
motorbikeshopUKcouk
My Bike: ZXR400
Post by motorbikeshopUKcouk »
ZXR400H1
I know the 3-way GSXR600/750/1000 K1,K2,K3 slots straight in, anything else? Anyother later Kawasaki shocks?
ZXR400H2
ZXR400L1-9
Would be useful if someone could pin this info, like you have done with the brake upgrade page?
ZXR400H1 FOR SALE £1500
L engine WANTED, Email: richardcharlesandrews1@gmail.com
Deswilkie
My Bike: ZXR400L, Trumpet 675
Re: Rear Shock Upgrades - What fits?
Post by Deswilkie »
I had an older ZX6R rear shock in my L model frame. Fitted with no mods and was adjustable whereas the standard wasn't.
ancozxr
My Bike: ZXR 400 Track, FMX 650
Post by ancozxr »
I want to upgrade also in my L model.
Suzuki K1-K3 600-1000 is the same?
ZX6 rear shock upgrade from what model ?
Racing for the fearless....!!!!
alanh
My Bike: zxr400 L racebike/R1
Post by alanh »
the gsxr one does not slot straight in, requires a small amount of modification. bottom hole needs drilled out to accommodate the zxr bolt and top needs either washers welded onto the zxr mount or the spacer carefully drilled as not to damage the bush, and the edges filed down to fit inside. ran one on my racebike this year and its a big improvement over standard, still found it a bit of a compromise for race use though. oh yeah, youll have to modify your rear subframe too as the shock fouls the brace bar on the underside
ZX4R-F3
My Bike: 1988 ZX400-F3
Post by ZX4R-F3 »
I fitted a 2002 ZX6 rear shock on mine.
viewtopic.php?f=87&t=12683
