Shock settings 80kg
Bailiff46
My Bike: Kawasaki ZXR 400
Shock settings 80kg
Post by Bailiff46 »
Anyone know what settings the shock should be for me?
It's a standard Kawasaki shock
Re: Shock settings 80kg
Set the static sag to between 6 to 10mm
After that all you have is 4 rebound settings if my memory is correct.
Ideally you should remove the standard shock and dispose of it carefully and fit a decent after market one. I like Ohlins myself others I'm sure will disagree.
KwakKwak
My Bike: ZXR 400L9 2001
Post by KwakKwak »
cargo wrote:Ideally you should remove the standard shock and dispose of it carefully and fit a decent after market one. I like Ohlins myself others I'm sure will disagree.
I for one strongly disagree, the standard shock is pure quality, until I sell the pile of crap that is, then and only then will I venture the Ohlins to be absolute perfection.
