Rear Link arm bearings
antares
My Bike: ZXR400
Post by antares »
Hi
I prep bikes for my daughter racing with BEMSEE in the rookie 400. We have previously raced a GSXR400 but have now purchased a ZXR400 L in 'semi' race trim. I am working through it and putting new bearings in the rear linkage system. On thing I notice is that where the rear linkage arms come together on the bolt passing through the (I do not know the technical term for the 'seesaw' that connects to the bottom of the suspension unit) there is a bearing - this is fine. However, at the top of the linkage arms there is not a bearing but just metal sleeves (tubing) with the bolts passing through it. These are quite sloppy with considerable play. Is this correct?
Many thanks for any helpfull comments.
Re: Rear Link arm bearings
here is the image you are looking for:
http://www.cmsnl.com/kawasaki-1994-l4-z ... ml#results
if you need parts call cradley kawasaki.
alanh
My Bike: zxr400 L racebike/R1
Post by alanh »
you heathers dad?
antares
My Bike: ZXR400
Post by antares »
Yup, I'm Heather's dad. Sorted the suspension. When I looked at it I see there should be Oilite glacier bearings in the arms. These had completely worn away as had the steel sleeves that run inside them. Bought two new glaciers from The Bearing Shop (amazing ranges of bearings) my mate pressed them in and turned up new steel sleeves from them. Everything is now really smooth with no play anywhere. Heather and I rebuilt the back end (still with standard shock - roll on sponsorship!) so now its on to get the front end sorted. Brake lever goes back to the bars because the master cylinder is knackered. Bought a newish 14mm GSXR master cylinder to fit. Already got six pot Honda calipers fitted so should be stoppies no problem.
alanh
Post by alanh »
i ran the same m/c, GSXR tokico 4 pots are usually the calipers of choice as the 6 pots are a pain in the butt to get to bleed up properly and lack feel in comparison. I spoke to heather earlier about the gsxr shock upgrade, better than stock and cheap but not as good as an aftermarket one. don't mess about with fancy fork internals though, myself and colin martin both run standard internals just set up correctly and are more than up to the job, just replace bushes and seals with decent quality ones (get all my suspension bits from steve Jordan, tell him you race with bemsee too its a bit cheaper usually) run a wilbers race shock, brilliant kit easily as good as ohlins. Clearances need kept on top of a bit on these zxr's and camchain tensioner blades are prone to snapping so would replace that. some easy ways to get extra power from stock motors too. Plenty spares here if you need anything
antares
My Bike: ZXR400
Post by antares »
Thanks for the suggestions.
