rear shocks
Posted: Wed Feb 13, 2008 4:54 pm
by rover220
have got myself an SP item to replace my current one.
how long/hard a job is it to swap them out and does one need any special tools for the job?
Re: rear shocks
Posted: Wed Feb 13, 2008 5:02 pm
by deviant
never been at the one on the ZXR, but have taken them out of other bikes. the shock itself is easy, just undoing two bolts. The potentially time consuming part is how much other crap you have to take off to get at it. Any or all of:
Fairings
Tank
seat
battery
undertray
rear wheel
etc, etc.
But as I said, I've not tried on the ZXR. It could be really easy.
Re: rear shocks
Posted: Wed Feb 13, 2008 7:55 pm
pretty much as deviant said really.
defo the side panels and tank as the top of the shock sits underneath the tank. you will also need to hold the bike up by the subframe and not a padock stand, an abba stand would probably be perfect if you can borrow one.
Once you propped it all up, i think you just need to undoo the linkage bolts underneath the swingarm and then the nut at the top of the shock and it should all fall through.
Re: rear shocks
Posted: Wed Feb 13, 2008 8:00 pm
by rover220
cheers guys
seems easy enough. ill probably suspend the subframe from the garage roof.
Re: rear shocks
Posted: Wed Feb 13, 2008 8:05 pm
take note tho that the linkage bolts are proper tight!
Re: rear shocks
Posted: Fri Feb 15, 2008 11:58 am
by Northern ANdy
double deep socket for the top nut
