FFS! pissing footpeg bolt!!
MillaMeter
Post by MillaMeter » Fri Aug 20, 2010 8:20 am
I need to change my gear shifter on my 636 Ninja, (same setup as the 400) I took the whole rearset off, went to undo the bolt on the back... and it just rounded the alan hole. :smt013 :smt013 :smt013
Any ideas on getting this sodding bolt out without damaging anything would be lovely!?
Regards
Rich
Re: FFS! pissing footpeg bolt!!
Post by cargo » Fri Aug 20, 2010 8:29 am
Foot rest bolts are threadlocked in..............and that thread lock is factory supplied with a new bolt if you buy one.
Not easy to get it out..................before you started you should have applied heat lots of heat.....................now that it is rounded off you options are limited and will more than likely involve drilling...............
MillaMeter
Post by MillaMeter » Fri Aug 20, 2010 8:35 am
cargo wrote:Foot rest bolts are threadlocked in..............and that thread lock is factory supplied with a new bolt if you buy one.
shiiiiite.... thought as much, of well, guess my old man will be setting up the piller drill later then.
Cheers anyway cargo winks
Regards
Rich
Post by RedexRobB » Fri Aug 20, 2010 9:02 am
Yup, drilling is just about your only option had this problem myself the other Day when taking off my rear mudguard, giraffe allen bolts rounded out :-(
extonyg
My Bike: zxr 400 L1 uk
Post by extonyg » Fri Aug 20, 2010 1:12 pm
you might be able to bang a spline/torx socket into it.
or a 'round off' socket over the top of it
Post by masterofinsanity » Sat Aug 21, 2010 12:03 am
try the next size up allen key and blat it in with a hammer, bit of heat and bobs your uncle.......failing that cut it off with an angle grinder :smt003
rabidnz
My Bike: ZXR400L1
Post by rabidnz » Sun Aug 22, 2010 7:03 am
can you dremel a nice chunky slot into it and impact driver it out after aplying liberal heat/penetr8
