Zxr400 h1 swing arm help!!!
Posted: Sat Apr 01, 2017 5:15 pm
by jackzxr
Hi all, I hope someone can help!
I have the h1 and the swing arm has a T shaped piece that can be removed so that the chain can be removed without the need to split it. For the first time ever I have removed this piece as part of the restoration project to find it has broken in two and only had the bolt holding the two parts in place.
Any ideas on where i can find a new one or fix this one?
Kind regards
Jack
Re: Zxr400 h1 swing arm help!!!
Posted: Mon Apr 03, 2017 9:27 am
by banner001
its a simple item for a machinist to mill from aly, probably cost you £50 plus the cost of a small offcut of aly.
my mate runs a waterjet company - "aquajet" in coventry. if you give them the dimensions or post the damaged one to them im sure they can sort you out, half the workforce are bikers, one used to run his own hire business and breakers yard.
failing that, the part number is 59071-1134-CE, you can give cradley kawasaki a ring, but i doubt they have the part, or can get hold of it for you.
the t piece snapping is a fairly common problem, you might have to buy a whole swingarm and take it from that...though i cant find any for sale at the moment, but motorcycle breakers may have one in stock...
Posted: Mon Apr 03, 2017 11:04 am
by watsonm359
Did you post this request elsewhere in this forum as I replied to the message? I've got a spare one in my garage, but that's in Norfolk and I'm currently in South Wales for the next two weeks. I may however be going back this weekend, so if you still want one and can wait I'll post it to you.
PM if you're interested with details of where to send it.
