cant get a spark from my race bike
all components are working as i have tested them in my other bike just cant get a spark please help
please help
- Harvey Wishbone
- Harvey Wishbone
Hi thorny. No it shouldnt be pulsing the voltage at the coils (red wires)should be 12volts if your battery is good. Dont let Harvey confuse you! if you have trimmed the wiring loom and removed the ignition switch?
The grey wire feeding the cdi needs to be reduced to 9volts,anything above this will stop the spark. there are two option! take the ignition swich apart and remove the 100 ohm resistor and wire it into the loom or buy some from an electronics supplier,they cost around 10p each. I have a race wiring diagram if you are stuck? post your phone number and i will contact you.
